![]() | Home > Technical (L322) > Air Suspension fault |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
F/left voltage way out of range -- have you calibrated the system (not sure if iCarsoft will let you do that) ? Current: 2011 FFRR Vogue SE 4.4 TDV8
Joe Plumber Member Since: 12 Feb 2019 Location: Devon Posts: 7 ![]() ![]() ![]() |
Hi your correct the icarsoft wont let you do that been looking at other fault readers like the iiD unit but i cant justify £500 at the moment and in answer to your question No I've not had it calibrated but looking to find someone in my area that can do it.
If you still have the old one, try refitting that see if it sorts it ?
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
I can vouch for using the IID Tool to correct this issue - my recently acquired '04 plate was low at the front left and it only takes 10 minutes to correct it using the IID guided calibration utility. I managed to pick up a used tool from the site, but otherwise I'd have been giving Duckworths £405 for a new one.
Thanks for the input, any idea what a garage will charge for calibration |
I'd imagine you will have less specialist options in Devon with the correct tools to do this - I have a local man in my village that has everything for Mercs, BMW's & JLR products and I image that I might have been able to sweet talk him into doing it for £50 or so, but I know that I'm going to need it again and again, so took the decision to bite the bullet right from day 1. |
Thanks for your input Ian and yes we do have specialists here in Devon & Cornwall, and believe it or not we have cars and roads to, As some people seem to think it just a place to keep sheep |
