![]() | Home > Maintenance & Mods (L322) > 110ah battery fit |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I have a new 110ah battery on my TD6 and I’ve just tried to fit it to the TDV8
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Ur -- this is covered in other posts -- not least one of my own, whilst an 020 battery will fit earlier models, 2010-2012 will only accept a 019 -- amp-hours aren't always related to size!
Thanks. It’s got a 100aH /900a on at the moment which I’m told was new in November. However there is no receipt with it and it’s got a 5 yr warranty.
Well mine is this: -
The battery on this one is Yuasa. Must be the same one |
If it is the same as the HSB019 then it's the wrong one for the car -- the HSB019 is not an AGM battery -- and the car should have an AGM battery fitted
Where does it say it has to have an AGM battery then? |
Most earlier versions of the 10MY were fitted with non AGM and were subject to a recall to fit AGM I believe.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I have a 020 agm in my 2011 VSE, tight fit but does go in |
Dolph, did you manage that and still have the scuttle drain pipe connected? Current: 2011 FFRR Vogue SE 4.4 TDV8
I have to admit that the indie i use fitted it for me so i dont know. I will jave a look tomorrow. I know he remove the plastic trim at each end of the battery. 2015 4.4 AB
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 ![]() ![]() ![]() |
My 07 TDV8 has a non original AGM fitted, its due for replacement but not sure what to fit, non AGM 020? |
