Home > In Car Electronics (L322) > Poor DAB reception.
bishbosh10
Poor DAB reception.
I thought it was just the binary nature of digital radio that made my DAB signal cut out so frequently but the other day I drove a hire car on my regular commute and didn't lose signal at all.
This tells me the DAB signal is fine and my RR's reception is rubbish.
Anything I can do to improve matters? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #506373 25th Feb 2019 7:53pm
i get the same problem and put it down to interference from my rear dash cam...
Post #506390 25th Feb 2019 9:09pm
broncoupe
bang on the money some cables are better shielded than others ariel amp pickup noise
worse 1 I ever had was a reverse camera that had ignition supply knocked out Dab completely
Post #506398 25th Feb 2019 9:43pm
Redtail
Mine is total rubbish as well and whenever the reverse camera is on the DAB dies.
Would replacing the cables with decent shielded ones make it a lot better?
Thanks
Roy
Post #506402 25th Feb 2019 10:02pm
broncoupe
It can help but the cables are a lot thicker therefore harder to hide
I usually use BlackVue and don’t have too many issues
Have you tried draping the cable to see if moving it reduces the
Interference that’s what I would do first
I know we all like bargains but the cabling on stuff from a certain
Continent can be so bad you can’t even solder it
Post #506415 25th Feb 2019 11:55pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
just to throw a spanner in the works, every time I take mine to the dealers for a repair the DAB radio performs so much better for about a month after and then slowly deteriorates. Just before it goes in the channel change is very slow i.e. a few seconds delay before you hear sound, if I take it in for anything it always comes out as though it is a new unit. I queried it with the dealers to see if they do anything while it is there that could improve the speed and strength and they said they do nothing at all that could address the issue I describe....still does it though... I need more help than most...sorry !!
Post #506470 26th Feb 2019 2:37pm
broncoupe
now that's a giant spanner
Post #506500 26th Feb 2019 5:39pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I wonder if fitting another aerial amplifier in series would help solve the drop-outs?
Post #567295 17th Sep 2020 10:05am
