Home > Technical (L405) > "Restricted Performance", on longer, motorway trip
L405_NI_2013
Northern Ireland 2013 Range Rover Vogue SE SDV8 Santorini Black
Hi, I've had my L405 since last June (2018) and 4-5 times it has come up with a Red Triangle Showing "Restricted Performance", but oddly only after a continuous period of motorway driving, initially after 100 miles or so and more recently after 30-40 miles. Each time, I've continued (in limp mode) to my destination but the next time I started up, the warning has gone and no error reported. I've taken it in and put it on the ODB, but no obvious error related to the time of the warning. Luckily, the vast majority of my driving is shorter, non-motorway driving but it has me reluctant to embark on longer journeys (just in case).
Surely I cant be the first person to have this occurrence, any guidance greatly received.
Post #506374 25th Feb 2019 8:02pm
verydisco
That's annoying indeed.
Anything particular about it, say, high mileage, really low mileage? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #506377 25th Feb 2019 8:09pm
L405_NI_2013
Hey, thanks for the response
L405 2013, 90000 miles, don't know if that is significant or not
Post #506379 25th Feb 2019 8:11pm
L405_NI_2013
Oh, and have had my LR specialist do a smoke test to check for leaks and loose hoses, nothing found.
Post #506380 25th Feb 2019 8:13pm
Why continue in limp mode ?
Have you tried switching off & restarting straight away ? When my L322 had split hoses - that worked.
Then it’s tracking down the cause - though to me it sounds like some kind of faulty sensor.
Post #506383 25th Feb 2019 8:24pm
charlie croker mk2
Easy fix "change the fuel filter"
Post #506411 25th Feb 2019 11:37pm
charlie croker mk2
Well : did you fix it by swapping out the fuel filter ???
Post #507182 3rd Mar 2019 6:10pm
