Home > Technical (L405) > 2013 L405 occasionally judders when turning up a gradient
Stingclive33
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My 2013 4.4 autobiography occasionally makes a judder from the rear wheel when going up a gradient and turning at the same time. A diagram of the four wheels in the turn position appears in the center of the display.any ideas what this could be.
Post #505957 21st Feb 2019 8:42pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
research LTB00906NAS4, covers this very fault.. mine thumps on turns, but no images on the screen, just maybe its related though...
I do have the PDF but cannot seem to load this, help in this regard would be welcomed...
Post #505991 22nd Feb 2019 7:41am
marcochezzi
JPEGS...
Post #505992 22nd Feb 2019 7:43am
Stingclive33
Many thanks Marcochezzi,
This sounds just like the problem and what’s more it’s an easy fix and not expensive......hoooray it must be Xmas...I’ll let you know if it sorted it.
Cheers
Post #506004 22nd Feb 2019 10:16am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #506023 22nd Feb 2019 1:00pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I wonder if this is a warranty item? ....
Post #508374 12th Mar 2019 7:38am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I had the same issue with my 2013 SDV8 AB and the dealer fixed it under warranty. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #508382 12th Mar 2019 8:47am
marcochezzi
Go figure - My Fattie has been at JLR since last week Monday, took it in before the 5yr maintenance plan runs its course as the thump on turns was becoming more and more noticeable. despite their best attempts as per the technical bulletin a fresh brand new off the shelf transfercase was fitted, didn't cost me a dime, what a pleasure...!!
Post #508426 12th Mar 2019 2:08pm
That technical bulletin refers to NAS spec vehicles...
To me that would not cover ROW spec's??? Just a thought Thumbs Up
Post #508428 12th Mar 2019 2:22pm
marcochezzi
Cam-Tech-Craig Please explain, apologies but I am not sure of the abbreviations and if they fall part of our warranty terms and conditions
Post #508429 12th Mar 2019 2:27pm
verydisco
NAS: North American Specification (US cars)
ROW: Rest Of world l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #508443 12th Mar 2019 3:32pm
Thank you J Thumbs Up
If you read the document above, where it says MARKETS it refers only to NAS (as above) North American Spec
Hope that’s now clearer sir Thumbs Up
Post #508465 12th Mar 2019 6:14pm
Stingclive33
Judder fixed
Great succes as per Marcochezzi’s suggestion the transfer case was emptied flushed filled with oil flushed and refilled, software updated and hey presto no more judder.......thanks hugely to Marcochezzi : Yawn Bow down Bow down
Post #508487 12th Mar 2019 8:32pm
marcochezzi
Brilliant, glad it worked for you!!
Post #508516 13th Mar 2019 4:16am
marcochezzi
Thank you Cam & Verydisco. Admittedly I did not even note the market area detail you refer to, I found the bulletin purely because of researching the symptoms I was noting on the fattie.. I guess that we would then fall under ROW. Cannot see how the US market transfer case would be subject to this issue where the rest of the world possibly not from a warranty perspective.. But then we have the 5 year maintenance plan included in all our purchases and I do not know if this is a global offer or only certain countries..
When I booked her in for the royal flush I was dealing directly with the workshop manager at the time and he had mentioned a bulletin in this very regard applicable to our market, without my mentioning that I was even aware of the document which I had attached herein a few posts back..
Anyway, on questioning the procedure he replied that they do a lot of these, also quoted the double flush plus software update, but mentioned that on odd occasions they even go as far as stripping the case for clutch replacement...
In my case I was informed last Thursday or Friday that they had initiated a warranty transfercase replacement request with JLR HQ, which was approved to my benefit & pleasure.
Which means in iittle over 3 months both diffs have been replaced with new, both front & rear propshafts replaced with new, all sideshafts replaced with new and now new transfercase.. not bad for a vehicle with less than 20k miles, (if my km to mile converter works....)
3.5 months left of the 5 year JLR maintenance plan.... next week I tow my Jeep 200 miles to the mountain kingdom of Swaziland for some fun, let’s see what breaks or gives in then.....
Post #508518 13th Mar 2019 5:27am
