Home > General > Is the 2010MY worth the extra? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
My experience was that the 3.6 TDV8 was an acceptable replacement for the BMW 4.4 petrol, whereas the 4.4TDV8 was quite a step up. The 8 speed gearbox is a notable improvement too. Consider whether access charges or exclusions will be relevant to where you will be driving, based on the Euro emissions rating of the cars. Earlier cars seem less prone to corrosion than later. Only Range Rovers since 1988 |
18th Feb 2019 12:48pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3139 |
what's your budget. You can get a 4.4 TDV8 now for mid teens. don't be fooled by paying lots more for less mileage. Better a high miler on motorways than a low miler popping to the golf club and back. |
18th Feb 2019 2:49pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
When looking at S/C models last year, I decided it was worth the extra to get the 2010+ model year.
18th Feb 2019 3:31pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1017 |
I had a 2010MY 3.6 VSE, bought with 35k on it and sold 4 years later with 77k on it. In those four years I had only 3 real issues, all common and all fixed under warranty; fuel tank sender, egr left bank and low pressure diesel pump. Everything else worked faultlessly and it was a superb car. No rust on mine and as good as new inside and out when I sold it. You can now buy similar cars for around £10-12k, budget £3k pa for running costs and repairs and you should be fine. The trick is to find the right one, so no skipped servicing and fsh with either md or indy. Good luck |
18th Feb 2019 4:00pm |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 |
My suggestion to people interested in L322 ownership (regardless if it's a pre-facelift, a BMW engine, a Jag engine, or whatever engine or model year they choose) is to never max out your budget on the purchase price of the vehicle.
18th Feb 2019 4:25pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I second that! I'm a £1000 into my slush fund for post purchase issues...bottom arms, oil cooler replacement, wheel alignment and bits.. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Feb 2019 4:36pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Is it worth buying the ones which have been used for towing ?
18th Feb 2019 4:58pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Perhaps as CS says, look at where you are going in the car. You use the car a lot, do you need access to emissions zones? Fuel economy, is it a concern? Can you claim for business use etc.?
18th Feb 2019 5:06pm |
