Home > Maintenance & Mods (L322) > New owner...folding mirror problem. |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3182 |
Welcome Andy (hey my first newbie greeting!)
14th Feb 2016 7:40pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Welcome Andy.
14th Feb 2016 7:45pm |
andyshad Member Since: 14 Feb 2016 Location: yorkshire Posts: 2 |
Thanks dolpinboy..
14th Feb 2016 7:59pm |
Hi, it been a long time since I had to do it but yes i remember taking the shroud off (the bit you would normally colour code). As the mirror closes there is a contact made with the clip i'm talking about. this comes loose and simply needs refixing in place. It worked for me but my memory is sketchy. hopefully someone here will know what I'm trying to explain.
14th Feb 2016 8:27pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
The manuals and hand books are in the WIKI, top right of screen under fullfatrr.com...
14th Feb 2016 9:08pm |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
first try a mirror reset. push the fold button down twice in quick succession.this may fix it
14th Feb 2016 10:07pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
I shall have to try the reset. In hot weather (most of the time here), the RH mirror folds in then back out. The LH mirror stays closed. Ron B. VK2OTC
18th Feb 2019 7:01am |
sibelius Member Since: 19 Aug 2018 Location: worcestershire Posts: 19 |
Finally!! The reset didnt fix it, so I took the mirror cover off, found the plastic cover that fits over the micro switch. when I removed it the small metal arm that operates the switch had dropped off, fitted it back on and sure enough the mirror now folds in and stays folded. Thanks guys. |
30th Apr 2019 11:09am |
MONT322 Member Since: 22 Jan 2017 Location: Surrey Posts: 33 |
good skills |
30th Apr 2019 11:30am |
we should perhaps step back and take a long look at ourselves!! We no longer want to fold a mirror back ourselves, nor do we want to adjust it ourselves, let alone adust the drivers seat position!!
30th Apr 2019 11:36am |
