![]() | Home > Maintenance & Mods (L322) > Replacing/ADjusting Handbrake Shoes |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
When i did my tdv8 one wheel up in the air would spin freely. Not sure if that helps as its a later car but assume the same. Re rear jacking points if you have a tow bar and high lift jack under there is fine. Aternativel where the suspension meets the sub frame and then jack stands on jacking points either side. Current 2007 TDV8 Vogue Buckingham Blue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35620 ![]() ![]() |
from our wiki,
I can never understand why handbrake shoes ever need replaced on a car after all you only use them when the car is stopped. Cleaned up yes but replaced? How do they wear down? |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
@ nicedayforit - if the backing plate rusts and the pins holding the shoes in place fall out/tear out of the backing plate, the shoes will fall onto the inside of the drum. That is one sure way of needing new handbrake shoes 56 TDV8 Vogue SE
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
@ Andy_J - No, you need a new backplate, not new brake shoes !! |
@ joe90 - unless you are lucky and notice the problem straight away, then the shoes rum on the bottom of the disc centre (drum) and overheat so when you go to fit a new back plate the shoes are shot. |
