Home > Maintenance & Mods (L322) > Replacing/ADjusting Handbrake Shoes
stuart_2006
I need to have a look at replacing/adjusting the handbrake shoes on my TD6. Question: if I leave the main gearbox in Neutral and raise just one rear wheel, is that wheel free to rotate? Or do I need to raise both rear wheels? If the latter is correct (and I think it might be ...), is there a suitable central jacking point for a trolley jack? (And yes,I've got some axle stands as well!)
Thanks!
Post #505134 14th Feb 2019 6:56pm
kbald
When i did my tdv8 one wheel up in the air would spin freely. Not sure if that helps as its a later car but assume the same. Re rear jacking points if you have a tow bar and high lift jack under there is fine. Aternativel where the suspension meets the sub frame and then jack stands on jacking points either side. Current 2007 TDV8 Vogue Buckingham Blue
Post #505489 17th Feb 2019 6:16pm
from our wiki,
https://www.fullfatrr.com/forum/post3786.html#3786
Post #505491 17th Feb 2019 6:20pm
I can never understand why handbrake shoes ever need replaced on a car after all you only use them when the car is stopped. Cleaned up yes but replaced? How do they wear down?
Post #505500 17th Feb 2019 7:53pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
@ nicedayforit - if the backing plate rusts and the pins holding the shoes in place fall out/tear out of the backing plate, the shoes will fall onto the inside of the drum. That is one sure way of needing new handbrake shoes 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #505516 17th Feb 2019 11:14pm
@ Andy_J - No, you need a new backplate, not new brake shoes !! Twisted Evil
However, if you fit a new brake disc, you would likely fit new disc brake pads, therefore it may follow you would fit new shoes as well..... .
Post #505518 17th Feb 2019 11:30pm
Andy_J
@ joe90 - unless you are lucky and notice the problem straight away, then the shoes rum on the bottom of the disc centre (drum) and overheat so when you go to fit a new back plate the shoes are shot. Thumbs Up
If you are really unlucky the pins end up getting dragged into the shoes and gouge them out along with the disc/drum and you need to fix the whole lot 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #505607 18th Feb 2019 9:28pm
