Home > General > MOT Farce
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
MOT Farce
So I sit there for an hour , and the MOT tester hands the keys back to the receptionist and tells her to tell the customer ( he hadn't seen me ) that he has had to abandon the MOT due to safety reasons as he was unable to safely lift the vehicle wheels off the ramp to conduct the various checks around the suspension ! Seems he had trouble with the jack that runs across the ramp being able to lift the car sufficiently to get the wheels up. Censored
Any one else ever had this ?
Post #505187 15th Feb 2019 10:46am
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Surely they would have known this when they booked it in.
Had one a few year back where the MOT finished and the guy came in to give me my keys. Before he got there VOSA walked in and said they wanted to do a random MOT test on my car. Passed with no minors, just as the garage had done
Post #505188 15th Feb 2019 11:09am
The mot tester appears to have had insufficient spacer blocks for the jack to be able lift the car high enough. Not uncommon problem with these cars given the drop on the wheels when the car is lifted.
Had my car lifted on the jack once and the tester was unable to get the car off again for a similar problem. We had to use a transmission jack to hold the car up whilst the ramp was lowered and the blocks removed to then allow the wheels back onto the ramp.
Post #505191 15th Feb 2019 11:24am
My MOT station has an array of hardwood blocks for just this occasion... Sounds like a jobs worth to me... Whistle
Post #505192 15th Feb 2019 11:31am
DaveK
I use blocks on my mates ramp to with out any problems. Yes, complete jobsworth who having been under the vehicle could also see two brand new steering arms, ball joints, bushes drop links on both sides , still gleaming from being fitted two weeks ago.
Post #505194 15th Feb 2019 11:38am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
My previous L322 went into the little old-fashioned garage which I've been using for about 30 years, every year for MOT. They have a pit rather than a ramp, with a cross-jack, and they never had any trouble lifting mine for inspection. Sounds like the guy was pratting about; I'd go elsewhere on principle as much as anything else.
Post #505198 15th Feb 2019 11:59am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Halfords in Ashford have a similar ramp problem and will not do my FF. The SL has no problem and they did that a couple of weeks ago. They did in fact fail it on a broken spring. New spring fitted and a positive re-test. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #505223 15th Feb 2019 3:06pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Find yourself a sensible MOT station, with a sensible tester.
I now this is not always easy, but will pay dividends. Thumbs Up
Post #505228 15th Feb 2019 3:58pm
a main dealer will test for about 50 odd quid, and they have proper lifts.
Post #505239 15th Feb 2019 5:16pm
DaveK
This was an independent bmw specialist in new built premises with 5 ramps and a 2 year old mot ramp. Not backstreet by any means. It’s a case of a P poor mot tester not knowing or willing to deal with a vehicle that is classed as plg due to insufficient knowledge of its suspension system. In which case, are they a fit and proper person to be making pass or fail decisions ?
Post #505248 15th Feb 2019 6:08pm
