Home > General > MOT Farce |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
Surely they would have known this when they booked it in.
15th Feb 2019 10:09am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
The mot tester appears to have had insufficient spacer blocks for the jack to be able lift the car high enough. Not uncommon problem with these cars given the drop on the wheels when the car is lifted.
15th Feb 2019 10:24am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
My MOT station has an array of hardwood blocks for just this occasion... Sounds like a jobs worth to me... |
15th Feb 2019 10:31am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
I use blocks on my mates ramp to with out any problems. Yes, complete jobsworth who having been under the vehicle could also see two brand new steering arms, ball joints, bushes drop links on both sides , still gleaming from being fitted two weeks ago. |
15th Feb 2019 10:38am |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
My previous L322 went into the little old-fashioned garage which I've been using for about 30 years, every year for MOT. They have a pit rather than a ramp, with a cross-jack, and they never had any trouble lifting mine for inspection. Sounds like the guy was pratting about; I'd go elsewhere on principle as much as anything else. |
15th Feb 2019 10:59am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Halfords in Ashford have a similar ramp problem and will not do my FF. The SL has no problem and they did that a couple of weeks ago. They did in fact fail it on a broken spring. New spring fitted and a positive re-test. 2017 5.0 Autobiography Supercharged
15th Feb 2019 2:06pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Find yourself a sensible MOT station, with a sensible tester.
15th Feb 2019 2:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
a main dealer will test for about 50 odd quid, and they have proper lifts. |
15th Feb 2019 4:16pm |
This was an independent bmw specialist in new built premises with 5 ramps and a 2 year old mot ramp. Not backstreet by any means. It’s a case of a P poor mot tester not knowing or willing to deal with a vehicle that is classed as plg due to insufficient knowledge of its suspension system. In which case, are they a fit and proper person to be making pass or fail decisions ? |
15th Feb 2019 5:08pm |
