Home > Technical (L322) > Deployable Steps - User Guide |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
have you tried topix? |
12th Feb 2019 6:51pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 334 |
Yes Stan, I did try that.
12th Feb 2019 6:59pm |
http://www.fullfatrr.com/gallery/albums/us...RRVDSS.pdf
12th Feb 2019 7:11pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Didn’t NMJ include a copy in his wiki topic for fitting ?
probably |
12th Feb 2019 7:13pm |
Stan
12th Feb 2019 7:48pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
12th Feb 2019 8:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Fig 119 on stans fitting instructions, look at the LHS where the hinge meets the step, the screw/bolt is illustrated as the small dome underneath... There are two on each hinge so 4 per side... |
12th Feb 2019 8:38pm |
Many thanks to you all. I think I’ve got it now, and even better, some tips on proper lubrication. |
12th Feb 2019 8:55pm |
I would suggest you soak the bolts multiple times with WD40 for some days before you attempt removal and only use a good quality allen key socket to move the bolts as they are prone to rounding off being allen keys! I changed all of mine to stainless torq bolts and greased them liberally before installation... |
12th Feb 2019 9:05pm |
thats a good tip craig.. |
12th Feb 2019 9:06pm |
Im not just a pretty face Stan... |
12th Feb 2019 9:08pm |
12th Feb 2019 9:17pm |
Many thanks Craig
12th Feb 2019 9:32pm |
