![]() | Home > Technical (L322) > Deployable Steps - User Guide |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
have you tried topix? |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 ![]() ![]() ![]() |
Yes Stan, I did try that.
http://www.fullfatrr.com/gallery/albums/us...RRVDSS.pdf
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Didn’t NMJ include a copy in his wiki topic for fitting ?
probably |
Stan
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Fig 119 on stans fitting instructions, look at the LHS where the hinge meets the step, the screw/bolt is illustrated as the small dome underneath... There are two on each hinge so 4 per side... |
Many thanks to you all. I think I’ve got it now, and even better, some tips on proper lubrication. |
I would suggest you soak the bolts multiple times with WD40 for some days before you attempt removal and only use a good quality allen key socket to move the bolts as they are prone to rounding off being allen keys! I changed all of mine to stainless torq bolts and greased them liberally before installation... |
thats a good tip craig.. |
Im not just a pretty face Stan... |
Many thanks Craig
