Home > Maintenance & Mods (L322) > Rear Diff Oil refill level on ETM Diff 2006 AJV8 Help |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
Mine has the same diff and the owners manual states 1.6L dry fill, 1.55L refill after drain. I put in 1.6L when I swapped the open diff for an e-diff 2 years ago. |
11th Feb 2019 6:23am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
GraemeS, was it easy or not so to swap differentials? 2012 TDV8 Black Edition
11th Feb 2019 9:13am |
The diffs are heavy - 2 people struggled with jacks but we got there. A hoist with an appropriate equipment jack would have made the task much easier.
11th Feb 2019 9:46am |
thank you GraemeS, 2012 TDV8 Black Edition
11th Feb 2019 10:09am |
11th Feb 2019 10:35am |
Blue Hornet Member Since: 24 Sep 2018 Location: Sawtell Posts: 17 |
Thanks Graeme yesterday I finished the oil change on the front and rear diffs and transfer case.
11th Feb 2019 8:20pm |
Are you sure that you have an ediff?
12th Feb 2019 2:26am |
Hi Graeme thank you for help after your question whether I have an Ediff I went and had a good look at my diff and its not an Ediff its the Open diff so thanks for your intuition.
12th Feb 2019 7:35am |
No harm in using ediff oil in an open diff other than the hole in your pocket. |
12th Feb 2019 9:13am |
