![]() | Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I like the mod Craig did on mine when he owned it, I like the clean look without the washer jets on the bumper and saves the fiddle polishing as well |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Will that pass an MOt I thought if you had xenon you needed headlight washers? Current stable:
Passed the last three of mine without an issue so I doubt it’s an issue |
AutoBiL322 Member Since: 10 Feb 2019 Location: Bath Posts: 42 ![]() ![]() |
Hi All,
You are out of luck my friend - I did a lot of research into this - the backs should go in with little issue... someone correct me if I’m wrong but the fronts have the airbags in the seats not the doors. If you have the new doorcards you need to disable the airbags or sand down the entry point otherwise you’d get a face full of shrapnel of it went off. Not sure if the bolt positions are the same or electrics or if you can even get the airbags to work... Current stable:
Thank you .. I did wonder as I couldn’t find any reference for it being done by anyone on the web.
On the washer question below, mine has failed an mot for the washer jets not working correctly as xenons needed to be washed.
wpo750 Member Since: 17 Nov 2018 Location: London Posts: 32 ![]() ![]() ![]() |
I've been a lurker here for a while but found myself a 2007 4.2 SC back in November last year. A few teething issues seemingly par for the course later and now I seem unable to continuously throw money at the RR. So much so it's currently in for the full Autobiography design pack treatment with some A and D pillar colour coding for added measure. It also seemed like a good time to have some corrosion taken care of on the rear wings and rear passenger door shuts. Hindsight suggests I may well have been wise to place the the funds into an upgrade to a later car but I had already bonded with this one and we're going all the way. Much like a trying relationship...
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Just thought I would add a point about the headlight washers. According to the MOT testing website, only cars with factory installed washer jets first used on or after the 1st September 2009 will need to have working jets. Cars registered before this are not tested for working headlight jets.
FYI jumping the wire for the 2003 and adding the x5 pump works fine.
Further to the above anyone done this on an 07? Current stable:
Ok....
Right for anyone else with an 07 plus as someone else has said only way I could get this to work is with relays
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
Any chance that Matt still has the photos and Dan can upload them back into the original post? Ron B. VK2OTC
