Home > In Car Electronics (L322) > Static on all radio channels
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Suddenly I'm getting static on all radio channels. I've not been messing with the audio/bluetooth/nav stuff, so I presume something has broken or failed.
Can't see any moisture in rear cubby where everything lives. I do have an issue where one or two radio stations have static when the rear screen demister is on. Now, even with the rear demister off, I get static on all stations.
Is the rear screen element also the radio aerial? I ask because my rear screen demister is very patchy at clearing the rear screen.
Any other common issues/resolutions I can look for please?
Post #503231 29th Jan 2019 6:12pm
this shows where the antennas are..
could be a bad earth?
Post #503234 29th Jan 2019 6:21pm
Gyre8
Thanks Stan. Very useful.
I was thinking (dangerous I know Smile ), a couple of days ago I had a 'Transmission Fault - Traction Reduced' message a few times on startup. No fault codes were thrown and and I had 14.7 volts with the engine running. but I understand that this fault can be triggered by a failing battery.
Iirc it's to do with low voltage on startup. Is this correct?
When the radio had static on all channels yesterday it was dark and cold so I had a lights, aircon, heated seat, etc, etc, switched on.
Battery is 18 months old Yausa from Halfords - so still under guarantee. But could a failing battery be causing the radio static issue?
Edit: Ref Bad earth. How do I check this please?
Post #503238 29th Jan 2019 6:47pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
When i charge my phone in car using a usb adapter in the aux plug i get static on the radio pull it out and it goes back to a perfect signal,a bit annoying but just put spotify on instead. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #503303 30th Jan 2019 10:17am
Gyre8
@Scottyav. Nothing plugged in to AUX. However today no static on radio channels, but I did get the 'Transmission Fault - Traction Reduced' message on startup.
Again no relevant fault codes thrown.
So probably battery or earth?
Post #503394 30th Jan 2019 10:07pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
I have had the same problem, mine was caused by the coat I was wearing. If the problem occurs, I exit the car close the door. remove said coat and get back in. works every time.
Must be my magnetic personality Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #504702 10th Feb 2019 12:27pm
Gyre8
Hmm. OK. I'll try driving around in the nip to rule out clothing related issues. What could go wrong?
Post #504795 11th Feb 2019 10:39am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
You could get a flat and have to change a wheel -- still look on the bright side -- it'd be a place to park your bike :O Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #504798 11th Feb 2019 11:02am
