Home > In Car Electronics (L322) > Static on all radio channels |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
this shows where the antennas are..
29th Jan 2019 6:21pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
Thanks Stan. Very useful.
29th Jan 2019 6:47pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
When i charge my phone in car using a usb adapter in the aux plug i get static on the radio pull it out and it goes back to a perfect signal,a bit annoying but just put spotify on instead. _____________________________________________________
30th Jan 2019 10:17am |
@Scottyav. Nothing plugged in to AUX. However today no static on radio channels, but I did get the 'Transmission Fault - Traction Reduced' message on startup.
30th Jan 2019 10:07pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
I have had the same problem, mine was caused by the coat I was wearing. If the problem occurs, I exit the car close the door. remove said coat and get back in. works every time.
10th Feb 2019 12:27pm |
Hmm. OK. I'll try driving around in the nip to rule out clothing related issues. What could go wrong? |
11th Feb 2019 10:39am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
You could get a flat and have to change a wheel -- still look on the bright side -- it'd be a place to park your bike :O Current: 2011 FFRR Vogue SE 4.4 TDV8
11th Feb 2019 11:02am |
