Home > Technical (L322) > Need a 4.4 TDV8 FBH guru |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Roger,
9th Feb 2019 7:53pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
Removing the connector from the reciever (as you did) is the best way to sync. Check fob battery as suggested but mine turned out to be a faulty reciever so if you can find someone else nearby to check your remote against their reciever or the other way round you should be able to find which one is faulty.
9th Feb 2019 9:09pm |
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 |
Checked fob battery and that’s okay. Also got power to unit.
10th Feb 2019 11:41am |
Hi Rog,
10th Feb 2019 3:10pm |
Yes Bushy is correct, the T91R has a digital output instead of analogue 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
10th Feb 2019 5:47pm |
