Home > Technical (L322) > Need a 4.4 TDV8 FBH guru
Page 2 of 3 <123>
DMRR
So time for an experiment Smile
Set the timed climate for 15-20 minutes before you get in the RR - that will be long enough to heat BUT only if the temp is below 15 degrees - otherwise (in theory) it will vent.
Change the batteries in your remote fob. Flashing red straight away means battery low from memory. When firing it up you should always get an amber and then either green for good or red for error. Flashing green means 'out of range'. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #491839 11th Oct 2018 7:57am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Sounds like a plan Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491842 11th Oct 2018 8:39am
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf
some good info here on the lights etc ( RCU ) and what the flashes indicate, hope it helps..!! I need more help than most...sorry !!
Post #491862 11th Oct 2018 12:42pm
Bushy30
Thanks Muppet Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491863 11th Oct 2018 12:53pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Did you ever resolve this as mine isn’t working now and if I try to operate it from the gap tool or even prime it, I get error E7 too?
Thanks.
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #504094 5th Feb 2019 10:19pm
Bushy30
Hi Ian,
Sorry to say I haven't, I actually think (hope) that when work was done to the front wing they forgot to reconnect mine, haven't got in there to look yet.
It would be really good to understand why E7 all the time though
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #504110 6th Feb 2019 8:50am
rjff
Bushy
If it's of any help, when I couldn't get the remote fob to work when we bought the car. (Yeh, should have checked it,), I opened it up and found two button batteries inside the unit. I replaced these with ONE CR1/3N battery and it paired up. (some numpty reckoned that using two 1.5volt LR something or other would be the same size as the 3 volt CR1 and work. They didn't touch the fob contacts correctly, or did not have the correct power, but got an orange flash)
Pushing the off button and getting a flashing red idicates not paired and a continuous red indicates paired.
By the way JLR say the CR1/3N is 3.3 volts, my new one gave 3.1volt and worked.
I, too have had the E7 but not gone futher yet. Cheers
Richard
Gap IIDBT
Post #504119 6th Feb 2019 10:43am
Bushy30
Richard,
Battery changed, fob paired, and works! Well fans run Very Happy
Not a peep out of the FBH though, and still have E7.
More investigation me thinks!
Previous: -
Post #504136 6th Feb 2019 2:36pm
rjff
Bushy Thumbs Up
I am wondering if the E7 code has something to do with a start failure or flame out after start or is a communication problem between the IID and the car. My FBH seems to operate on starting the engine or on the remote. I've just tried the IID and got E7 when trying to access the FBH. Did a hard reset and it now accesses the FBH and runs the test routines. As the car is still warm from a journey today, I may try again in the morning to see what happens with the remote and on car start, but I'll probably just add to the confusion Smile Cheers
Richard
Gap IIDBT
Post #504157 6th Feb 2019 6:01pm
Bushy30
Richard,
How do you do a hard reset?
Cheers
Previous: -
Post #504165 6th Feb 2019 6:53pm
rjff
Bushy
This is what I understand and did.
Turn off the car by pushing the stop/start button.
Leave it for several minutes, so it goes to "Sleep" (go have a brew or a beer)
Remove the negative battery wire from its terminal
Remove the positive battery wire from its terminal.
Wait for several minutes (annoy the wife by having another beer or brew)
Touch and hold the two wires (positive and negative) together for some time. (not quite sure how long)
Reconnect the positive then negative wires to thieir terminals
And should be job done. (cebrilate with another brew and wife leaving)
Not sure on all of what this can do/reset, but this routine seems to be one answer which comes up for the fullfat quite often. Cheers
Richard
Gap IIDBT
Post #504180 6th Feb 2019 8:41pm
Bushy30
Aha, that 'hard reset', thank you - -I think the only thing I tried was pulling fuse 13 -- so I might just give this a go!
Cheers Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #504283 7th Feb 2019 12:01pm
rjff
Thumbs Up Cheers
Richard
Gap IIDBT
Post #504299 7th Feb 2019 1:46pm
Martin
Site Admin
Bushy, feel free to drop up to Wroxton and see me, I have Webasto FBH diagnostics Thumbs Up
Post #504341 7th Feb 2019 5:12pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Rather than starting a new thread any suggestions getting a t91 remote to sync.
The fbh works in manual and timed.
Tried to sync the remote by disconnecting cable from transeiver waiting 10 secs and reconnecting and pressing off button on remote. Just get a few seconds of flashing red light on remote then off. The telestart is a t91 module and is next to fuse box not behind it. Car is 2012 vogue with a few factory extras.
There appears to be no fuse to remove as manual doesn't list one for fbh. I assume it sits on another circuit somewhere. Is there a way to see if the box is powered? Any suggestions greatfully received
Roger
Post #504633 9th Feb 2019 5:10pm
Page 2 of 3 <123>
