Thanks James,
Sounds similar to what may be causing my issues. The car is currently in the garage. Still awaiting an update but they've apparently found where the oil is leaking and currently changing seals/ components. I hope its this same leaks between the DPF sensors and they are aware of the turbo drain mod.
The car is still under warranty from the dealer I bought it from so no cost to me but hoping the garage they use know their stuff otherwise it could be an ongoing issue.
T 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
