![]() | Home > Technical (L322) > Flashing at the woman across the road |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 ![]() ![]() ![]() |
Hi guys; I’m after some pointers or ideas as electrical gremlins have struck today.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
fogs are only usable when the main dip is on so this is a weird one...somehow power is getting to this one fog light ... |
tell me about it .... have just disconnected it for the night cos its been going on and off randomly for hours now. Will try tracing fault on weekend if weather allows |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
One of my P38As did something similar. It was a problem in the BECM. Maybe the LCM in the L322? Ron B. VK2OTC
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Just a thought....
Cheers Miggit good idea as I've had probs with the towing sockets some years ago draining the battery through water and corrosion. All replaced and sealed. Have checked on the off chance but all ok. |
FAULT FOUND I think! After much searching I found the LCM in the A pillar was wet! No signs of water running down the pillar or bulkhead and whilst carpets were dry to touch the sponge underfelt was a little wet at the base of the pillar. So search was on for the source of the leak; all usual culprits checked sunroof drains all clear and running freely, plenum drains also ok. Running a hose over the roof and windscreen showed no signs of seepage that I could detect and even in the upper A pillar (with the airbag) all was dry even a little dusty. Totally mystified so after searching this great forum looked at the windscreen again. Its the original so not a prob from a screen replacement fitting. However, I noticed that the rubber trim where the roof strip for the roof bars joins the screen it was sitting a little proud. lifting the trim panel back it was obvious that there was a slight gap in the sealant at top of the screen. So following previous threads on similar water leak faults I've resealed the area as a precaution. Tested again with the hose and still no signs of a trickle inside so hope it was a one off caused by the recent freezing temps, snow and driving rain shrinking the sealant and allowing penetration. Time will tell |
