![]() | Home > Technical (L405) > Strange noise, every time |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
Now this is odd, I have asked questions on the forum before but never something like this.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Air being released from the seat inflatable cushions? |
That sounds quite logical but could it suggest a failing of the seat air cushion? It only started a few weeks ago and the car has about 37,000 miles. |
The wifes Merc did similar-just before the orthopaedic seats packed up |
Well that is an interesting idea that I will check tomorrow and report back.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Thats where id put my £1 bet sir |
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 ![]() ![]() |
...in my MY2016 the auto massage can be set only for the driver seat. 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
dfulgo is correct that it is only the drivers side that can be set to come on automatically and when I checked found that was already set to "off", I only use the massage function on longer journeys anyway. I couldn't see any settings to bring the passenger side on without doing it manually.
Have you stopped the car and looked? Does it make the noise when stationary? Only with a passenger using the seat for example? |
Craig,
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
I also have a strange creaking or groaning , its seems to come from under the fridge between the seats , its very pronounced on first few hundred yards from cold in freezing temps . I reverse down my drive and as I go into drive it sounds like two balloons being rubbed together and it happens again a few hundred yards later . Hardly ever happens in the warm temperatures . Special programs is off so as to prevent the centre diff from locking automatically in sub zero temps ! Is this a problem in the making or just a "feature" LOL |
