Home > Technical (L322) > Help identifying a piece of trim
topgeartowers
Hey lads,
I’ve recently had the Westminster detailed, and when I got it back there was this random piece of rubber trim left in the boot. Spoke with the detailers, but no luck on where it came from.
I’ve googled the item code, L322-RH 7H42-42431, but no luck there either. Can anyone help identify it for me?
Thanks
Post #503666 2nd Feb 2019 12:01pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
To me it’s the rubber trim that fits on the tailgate glass.
Myself and others have removed there’s.
https://www.island-4x4.co.uk/moulding-stri...34716.html
https://www.fullfatrr.com/forum/topic25132...p;start=30 Page3 Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #503668 2nd Feb 2019 12:03pm
mjdronfield
That’s the only thing that came to my mind too. Supposed to stop water dripping on the parcel shelf when you open the tailgate and the window is wet.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #503670 2nd Feb 2019 12:19pm
rjff
^^ I'm with the above.
When we bought ours, I asked the dealer to replace the corroded ones, which they did with soft plastic ones. Speak to Dan at Duckworths for info and a price. Cheers
Richard
Gap IIDBT
Post #503682 2nd Feb 2019 3:16pm
Mr Tee
That’s exactly what it is, did the pair of mine PITA job!
Post #503698 2nd Feb 2019 4:38pm
topgeartowers
Thanks lads! Love this forum.
Post #503711 2nd Feb 2019 6:28pm
topgeartowers
How come you removed them?
Post #504602 9th Feb 2019 2:47pm
topgeartowers
They look like they just slot on? Maybe some adhesive at the top to hold it? What did you have to do?
Post #504603 9th Feb 2019 2:49pm
oters have removed the trims because of the common corrosion at the bottom end...new ones slide back on, a bit fiddly but not that difficult..
Post #504604 9th Feb 2019 2:51pm
RRV78
I just pulled mine off they were corroded and bubbling at the bottom. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #504614 9th Feb 2019 3:15pm
