Home > Technical (L322) > L322 ABS relay location |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Can anyone tell me where the ABS is exactly?
5th Feb 2019 2:19pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Looking at the engine from the front (facing rear) it is a box with lots of hard steel pipes coming out of it at the rear right of the engine bay, near the windscreen. There is a large wire going into the lower right (pax) side (looking at it from front) which should be taken off and examined as its a water trap and corrodes the pins. A good clean up can work wonders.
9th Feb 2019 10:48am |
