Home > Photos, Videos & Media > Do faraday pouches really work?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35388 |
here's another method that might work,
31st Jan 2019 4:18pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
Thank you Stan. Gonna try that when Mrs 160 gets home with the car!
31st Jan 2019 4:34pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
I keep mine in a tight fitting biscuit tin and I tried it within a foot of the car door and it will not open the locks.
31st Jan 2019 5:58pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
Kitchen foil also works, but it's no where near as handy as having it in a open/close faraday bag. I only keep my spare key wrapped in foil since I never us it so the inconvenience is trivial. |
31st Jan 2019 8:40pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I bought Faraday bags off ebay (one for each the keys I have) around 20 months ago for @£5.50 each and they work fine. I also can put it in the bag, put it right next to the door handle and cannot open the door, so they obviously block the signal pretty well. The only thing I would say is that if you have your key fob on a ring with a bunch of keys, it might be a tight squeeze getting it into some of the bags and closing it as the ones I have seen are relatively compact - I keep mine separate so not an issue for me. Steve
1st Feb 2019 11:46am |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
Worked perfectly on my 2016MY |
1st Feb 2019 12:07pm |
splendid.. |
1st Feb 2019 2:13pm |
Got given a wee Faraday bag FOC by a locksmith who was admiring our RR yesterday. Was surprised by the simplicity of it and that it worked but it does. Put the keys in the bag and then approached the car and the doors won’t open. Press key fob buttons whilst the fobs are in the bag and even standing right next to the car, nothing worked when pushing the buttons. |
12th Jul 2020 7:27am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 456 |
I think they do work, once in the bag I cannot open the doors nor start the engine if the key is in the bag. That said I also have a telescopic security post on my drive as an extra deterrent and two 4 legged friends with good hearing for anyone snooping around. |
12th Jul 2020 7:52am |
surely the whole point of keyless entry is that you have the key in your pocket/hand bag/man bag/under your flat cap if you're 'up north', and you walk up to your FF and the door is open..
12th Jul 2020 8:06am |
If I’m not mistaken Stan, and I maybe, the thieves can still open you car even if keyless entry is disabled if they can can receive your key signal, hence whether it’s on or off I’d still use a faraday bag.
12th Jul 2020 8:24am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
If the system is disabled then the "usual" method of scanning around your perimeter for a signal no longer works...
12th Jul 2020 10:34am |
Another quick point to make...
12th Jul 2020 11:17am |
I’ve always used the double press deadlock facility.
12th Jul 2020 12:03pm |
