![]() | Home > Technical (L322) > snow mode, front diff unlocked |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
used the FF in the snow today and switched on the 'snow/gravel' mode and the dash showed the front diff unlocked....
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Snow, ?
you're missing all the fun we're having here Mike.. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
My understanding is it auto locks when the RR decides it needs to due to wheel slip/spin etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
That is my understanding as well.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I guess that you're referring to the centre diff. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Wasn't aware of any L322 fitted with a locking front diff...
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 ![]() ![]() ![]() |
If the front diff locks you'll lose steering! |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
There is no 'benefit' as such, the car is just showing you what it is doing, so the car is driving fine in the standard setting despite the snow. If traction is being lost then the padlock symbol changes to closed to show the differential being locked. You'd feel it too. Only Range Rovers since 1988 |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
It's all great stuff but absolutely useless if a load of jacknifed cars and lorries in front and behind you are blocking the road |
The display doesn't tell the whole story. If you monitor the locking % using an IIDtool then you will see that the centre and rear e-diff, if fitted, are often pre-loaded to varying degrees even when no special program is in use yet not loaded high enough to trigger the locked symbol. The locked symbol only shows once a threshold has been reached and when shown, doesn't mean that the diff is effectively locked solid. As I've churned through mud, once the e-diff lock symbol shows, the locking % can reduce to well below the threshold yet the lock symbol stays on, only going off if the diff remains below the threshold for an extended time. |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
As stated previously with a front diff locked you get real lousy steering , when competing (in 90) I usually run centre and rear locked and leave the front free unless I know I'm going to need it , it's then ulocked as soon as possible as you've got |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
matthews
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
Torsen diff locks can be used on steering axles without steering lose and are fully automatic. |
