Home > Photos, Videos & Media > Do faraday pouches really work?? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3156 |
31st Jan 2019 2:09pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 690 |
Allegedly, if the key is not totally enclosed & therefore some of the key signal can "escape" they're no use. Paul,
31st Jan 2019 2:15pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2649 |
Crap, been using them for the Fullfat & a BM with comfort access. Guess a wee test when I get home is called for |
31st Jan 2019 2:46pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
The reception or transmission of radio waves, a form of electromagnetic radiation, to or from an antenna within a Faraday cage is heavily attenuated or blocked by the cage; however, a Faraday cage has varied attenuation depending on wave form, frequency or distance from receiver/transmitter, and receiver/transmitter power. Near-field high-powered frequency transmissions like HF RFID are more likely to penetrate. Solid cages generally attenuate fields over a broader range of frequencies than mesh cages.
31st Jan 2019 3:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
can you not switch this function off and just use the buttons on the key fob... |
31st Jan 2019 3:15pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
Interesting subject.
Good point Stan - I have really tried to do that several times and can't get it to turn off on my 2014 L405 2016 (L405) Autobiography in Black with Ivory - for ULEZ
31st Jan 2019 3:16pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1253 |
As mentioned in another post, it doesn't really matter with Range Rovers as they usually break down within 10 minutes!! |
31st Jan 2019 3:21pm |
have you tried this,
31st Jan 2019 3:22pm |
Yes I have and I cannot make it work - the keyless entry still operates just the same! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
31st Jan 2019 3:57pm |
I can actually rest the key (in the faraday pouch) on the door handle and still the door will not unlock when I try it - can't get closer proximity than that! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
31st Jan 2019 3:59pm |
31st Jan 2019 4:04pm |
thats a nice little man bag.. |
31st Jan 2019 4:05pm |
This is the bag which definitely works.
