Home > Photos, Videos & Media > Do faraday pouches really work??
Page 1 of 4 1234>
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
https://www.dailymail.co.uk/news/article-6...ngham.html
Shocked Shocked
Post #503449 31st Jan 2019 2:09pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Allegedly, if the key is not totally enclosed & therefore some of the key signal can "escape" they're no use. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #503450 31st Jan 2019 2:15pm
CS
That is my understanding too. Wrapping in aluminium foil seems to work and you can test it by approaching your car with the wrapped key and seeing if it will open. By contrast I tried it with a quite tight sealing metal tin and the car opened. So worth testing pouches too. I've read about them not working, or maybe being inconsistent, not just in that article. Only Range Rovers since 1988
Post #503453 31st Jan 2019 2:31pm
Mr Tee
Crap, been using them for the Fullfat & a BM with comfort access. Guess a wee test when I get home is called for
Post #503456 31st Jan 2019 2:46pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
The reception or transmission of radio waves, a form of electromagnetic radiation, to or from an antenna within a Faraday cage is heavily attenuated or blocked by the cage; however, a Faraday cage has varied attenuation depending on wave form, frequency or distance from receiver/transmitter, and receiver/transmitter power. Near-field high-powered frequency transmissions like HF RFID are more likely to penetrate. Solid cages generally attenuate fields over a broader range of frequencies than mesh cages.
So, try wrapping it in lead -- or dropping it in an old lead lined tea caddy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #503459 31st Jan 2019 3:11pm
can you not switch this function off and just use the buttons on the key fob...
Post #503460 31st Jan 2019 3:15pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Interesting subject.
I was given one by Disklabs to test and they really do work.
I was going to set up a group buy.
Would that be of interest? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #503461 31st Jan 2019 3:15pm
160dmb
Good point Stan - I have really tried to do that several times and can't get it to turn off on my 2014 L405 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #503462 31st Jan 2019 3:16pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
As mentioned in another post, it doesn't really matter with Range Rovers as they usually break down within 10 minutes!!
Post #503464 31st Jan 2019 3:21pm
have you tried this,
Post #503465 31st Jan 2019 3:22pm
160dmb
Yes I have and I cannot make it work - the keyless entry still operates just the same! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #503469 31st Jan 2019 3:57pm
160dmb
I can actually rest the key (in the faraday pouch) on the door handle and still the door will not unlock when I try it - can't get closer proximity than that! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #503470 31st Jan 2019 3:59pm
160dmb
Post #503471 31st Jan 2019 4:04pm
thats a nice little man bag.. Mr. Green
Post #503472 31st Jan 2019 4:05pm
160dmb
This is the bag which definitely works.
I will inquire about special pricing for a bulk purchase if people are keen 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #503473 31st Jan 2019 4:05pm
Page 1 of 4 1234>
