Home > Maintenance & Mods (L322) > ‘Bong’ brake fluid level low |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Be very wary! Could be corroded brake pipe(s). Mine went (fore to aft) under the passenger side. There are plenty of write-ups about this problem if you do a search. Previous cars:
30th Jan 2019 12:26pm |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 |
I wouldn't drive it in that condition. it's just not worth the risk. First place to look for a leak is from the flexible hoses to the calipers where the brake work was done. Even if you "topped up" the brake fluid reservoir, the leak may suddenly get a lot worse! |
30th Jan 2019 12:27pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
+1 for brake lines 2015 4.4 AB
30th Jan 2019 12:34pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
Try applying the footbrake hard & holding the effort for a minute.
30th Jan 2019 12:40pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Be aware if yours is diesel doing the foot brake check with a running engine will give you diesel creep
30th Jan 2019 1:44pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Cheers guys
30th Jan 2019 1:54pm |
Pawl, when the engine is idling the brake pedal does fade a lot, but I tried it with the engine off and it was very firm with no travel and sat in its normal position? |
30th Jan 2019 1:57pm |
AA been out, corroded pipes that run length of the car under the passenger side ☹️
30th Jan 2019 2:29pm |
Corroded pipes are only a significant issue if they're leaking - although they may fail in the future & corrosion can be an MOT failure if they believe they're reduced in thickness by >25%.
30th Jan 2019 3:30pm |
Cheers again guys, a nasty bout of man flu has immobilised me so soon as I’m back up on 2 feet, I’ll lay under the b&st@rd thing
31st Jan 2019 2:07pm |
You'll still have brakes that work leaking rears mean reduced rear braking fronts are fine that's why they run on different circuits to get you home
31st Jan 2019 7:47pm |
Cheers Henda, spoke to a local garage who said run it up to them to prove up the work but I decided against it because didn’t want total failure of them on my way there, so guess it could limp the 3 miles to the workshop to get it looked at after all?
3rd Feb 2019 9:17am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
For peace of mind I would get the lot replaced. If there are corroded pipes it can only be a matter of time before they go too. John
3rd Feb 2019 9:58am |
When I did mine I had the flexi pipes replaced as they were starting to corrode
3rd Feb 2019 10:10am |
