![]() | Home > Maintenance & Mods (L322) > ‘Bong’ brake fluid level low |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Be very wary! Could be corroded brake pipe(s). Mine went (fore to aft) under the passenger side. There are plenty of write-ups about this problem if you do a search. Previous cars:
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
I wouldn't drive it in that condition. it's just not worth the risk. First place to look for a leak is from the flexible hoses to the calipers where the brake work was done. Even if you "topped up" the brake fluid reservoir, the leak may suddenly get a lot worse! |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for brake lines 2015 4.4 AB
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
Try applying the footbrake hard & holding the effort for a minute.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Be aware if yours is diesel doing the foot brake check with a running engine will give you diesel creep
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 732 ![]() ![]() ![]() |
Cheers guys
Pawl, when the engine is idling the brake pedal does fade a lot, but I tried it with the engine off and it was very firm with no travel and sat in its normal position? |
AA been out, corroded pipes that run length of the car under the passenger side ☹️
Corroded pipes are only a significant issue if they're leaking - although they may fail in the future & corrosion can be an MOT failure if they believe they're reduced in thickness by >25%.
Cheers again guys, a nasty bout of man flu has immobilised me so soon as I’m back up on 2 feet, I’ll lay under the b&st@rd thing
You'll still have brakes that work leaking rears mean reduced rear braking fronts are fine that's why they run on different circuits to get you home
Cheers Henda, spoke to a local garage who said run it up to them to prove up the work but I decided against it because didn’t want total failure of them on my way there, so guess it could limp the 3 miles to the workshop to get it looked at after all?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
For peace of mind I would get the lot replaced. If there are corroded pipes it can only be a matter of time before they go too. John
When I did mine I had the flexi pipes replaced as they were starting to corrode
