Home > Technical (L322) > TPMS showing 100 kpa on all 5 wheels.
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
I've got an intermittent glow in the TPMS warning light. When connecting the IID Tool it shows 100KPa on all 5 wheels.
Being an idiot I cleared the original fault codes without properly storing them, and sinsce this, the fault codes that were present on the TPMS has not re-occured.
IR-receiver? TPMS Module?
Obviously I'm not driving around with 1 bar in each wheel. 2007 L322 3.6 TDV8 Stornoway
Post #494308 1st Nov 2018 8:52am
S.Hafsmo
No thoughts? Likely to be the receiver?
Seems the system is waiting for the wheels to sync. I've just bought the car, so for all I know, all the five batteries are dead.
Post #494484 3rd Nov 2018 6:05am
i had nothing but trouble with mine so i switched it off with the iidtool..,didnt miss it at all....
Post #494486 3rd Nov 2018 7:57am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Where on the IID tool do you get this screen? 2012 TDV8 Vogue SE 4.4
Post #494503 3rd Nov 2018 11:35am
S.Hafsmo
Where you choose live view values. You can also choose the spare, but it's on a separate window and not in the graphic. 2007 L322 3.6 TDV8 Stornoway
Post #494504 3rd Nov 2018 11:36am
Frans@Yamorna
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #494506 3rd Nov 2018 11:52am
S.Hafsmo
Minor update. After driving a few hundred miles I've gotten the fault codes back on the TPMS.
Each wheel shows code C1A56-31 (E8) (individual Wheel codes, 56, 58, 60, 62).
A more interesting code that appeared is from the receiver above the sunroof panel.
C1D19-87 (28) External receiver data line - Bus signal/Message failure - Missing a Message.
So I'm hoping this module would be the issue. 2007 L322 3.6 TDV8 Stornoway
Post #496894 28th Nov 2018 2:38pm
S.Hafsmo
Another minor update.
I've replaced the receiver above the mirror - no change.
Replaced all wheel sensors - no change.
While doing a different repair, I found one of the antennas (front, left) was missing. I've ordered a new antenna, but surely this wouldn't cripple the whole system?
Seems I'll be in the market for a new TPMS module in the future. 2007 L322 3.6 TDV8 Stornoway
Post #503173 29th Jan 2019 11:05am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
My TPMS works usually when there is an R in the month.......useless system. Wink David
Please let me know if my comments upset you, I may wish to upset you again.
Post #503205 29th Jan 2019 1:58pm
Sandyt
Me too nothing but trouble and if enabled and not working an mot failure I think
Post #503224 29th Jan 2019 5:26pm
S.Hafsmo
Replaced module pn: NNW502305. TPMS back in business.
Post #533074 3rd Nov 2019 8:37pm
Boxbrownie
If that’s Lbs/Sq” the tyres are a bit over inflated 😂 David
Post #533099 4th Nov 2019 8:13am
S.Hafsmo
it's kPa. Though I'm not certain it's accurate. Will have to check.
330 kPa is still 48 PSI, so a bit over inflated. I also think the front/rears have swapped position, as the rears should probably have the higher pressure.
Post #533103 4th Nov 2019 9:00am
