![]() | Home > Technical (L322) > TPMS showing 100 kpa on all 5 wheels. |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
No thoughts? Likely to be the receiver?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
i had nothing but trouble with mine so i switched it off with the iidtool..,didnt miss it at all.... |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Where on the IID tool do you get this screen? 2012 TDV8 Vogue SE 4.4 |
Where you choose live view values. You can also choose the spare, but it's on a separate window and not in the graphic. 2007 L322 3.6 TDV8 Stornoway |
Minor update. After driving a few hundred miles I've gotten the fault codes back on the TPMS.
Another minor update.
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
My TPMS works usually when there is an R in the month.......useless system. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Me too nothing but trouble and if enabled and not working an mot failure I think |
Replaced module pn: NNW502305. TPMS back in business.
If that’s Lbs/Sq” the tyres are a bit over inflated 😂 David
it's kPa. Though I'm not certain it's accurate. Will have to check.
