Home > Technical (L322) > New air suspension woes! ***updated***
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I’m getting the usual air susp inactive error.
When I plug it in it’s saying reservoir static while filling or something similar??
When I reset the code it works fine, if a little slow (seems to be about 2-3bar until I leave it alone to increase).
Any ideas?
Also intermittently getting something about the auto box program?
Post #498905 17th Dec 2018 1:00pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Reservoir static is usually the pump -- you can get a repair kit to replace the piston 'O' ring Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #498908 17th Dec 2018 1:19pm
Danbhardy
Is it easy to do?
Post #498911 17th Dec 2018 1:34pm
Bushy30
I did the one on my 04 plate, took about 30 mins to whip out the pump, change and put back -- that might be a bit optimistic though, there were two of us, and we were in a hurry! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #498913 17th Dec 2018 1:38pm
Danbhardy
Haha never done anything like this before.
Are the pumps cheap enough?
Post #498914 17th Dec 2018 1:41pm
Bushy30
You don't need the pump, just a repair kit -- my supplier was a chap called Bagpipe Andy -- found him on ebay -- not the cheapest, but very good kit, full instructions etc Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #498915 17th Dec 2018 1:47pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Did mine on my 04 TD6 very easy to do just followed bagpipping Andy on YouTube.
Post #498917 17th Dec 2018 2:27pm
Bushy30
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #498918 17th Dec 2018 2:30pm
Danbhardy
Ok, done the o ring and piston ring but plugged it in and same error Sad
It’s getting to about 3 bar or just under then the valves are closing and the pressure drops steadily to about 1 bar Sad
Any ideas?
Post #503183 29th Jan 2019 12:16pm
Bushy30
Sounds like you have a leak somewhere then. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503187 29th Jan 2019 12:39pm
Danbhardy
Any tips on finding it? As my suspension is staying up and not leaning anywhere??
Post #503190 29th Jan 2019 12:43pm
Bushy30
Try the reservoir tank itself, or the pipes leading to or from it Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503196 29th Jan 2019 1:10pm
Danbhardy
Is the reservoir tank part of the compressor which I removed? Or somewhere else lol
Post #503198 29th Jan 2019 1:39pm
The reservoir is under the driver (RHD) and rear passenger seat (outside the car!!), runs in the channel between the sill and the floor .
Post #503201 29th Jan 2019 1:46pm
Bushy30
page 396 of the workshop manual which can be downloaded from a link towards the bottom of the wiki -- gives you an exploded diagram Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503202 29th Jan 2019 1:46pm
