![]() | Home > Technical (L322) > New air suspension woes! ***updated*** |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Reservoir static is usually the pump -- you can get a repair kit to replace the piston 'O' ring |
Danbhardy Member Since: 10 Nov 2018 Location: Chorley Posts: 44 ![]() ![]() ![]() |
Is it easy to do? |
I did the one on my 04 plate, took about 30 mins to whip out the pump, change and put back -- that might be a bit optimistic though, there were two of us, and we were in a hurry! Current: 2011 FFRR Vogue SE 4.4 TDV8
Haha never done anything like this before.
You don't need the pump, just a repair kit -- my supplier was a chap called Bagpipe Andy -- found him on ebay -- not the cheapest, but very good kit, full instructions etc Current: 2011 FFRR Vogue SE 4.4 TDV8
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
Did mine on my 04 TD6 very easy to do just followed bagpipping Andy on YouTube. |
Ok, done the o ring and piston ring but plugged it in and same error |
Sounds like you have a leak somewhere then. Current: 2011 FFRR Vogue SE 4.4 TDV8
Any tips on finding it? As my suspension is staying up and not leaning anywhere?? |
Try the reservoir tank itself, or the pipes leading to or from it |
Is the reservoir tank part of the compressor which I removed? Or somewhere else lol |
The reservoir is under the driver (RHD) and rear passenger seat (outside the car!!), runs in the channel between the sill and the floor .
page 396 of the workshop manual which can be downloaded from a link towards the bottom of the wiki -- gives you an exploded diagram |
