Home > Maintenance & Mods (L322) > Rear washer not working.. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
loads on the forum re this, have a search..
29th Jan 2019 11:19am |
RRAustria Member Since: 07 Apr 2015 Location: Graz Posts: 32 |
Thanks Stan. Unfortunately I didn't find what I'm looking for. The wiki and most threads talk about faulty wiper motors/seals, non-return valves, pumps - all these possible causes have been ruled out in my case (pump is running, line is disconnected before one-way valve and motor).
29th Jan 2019 11:43am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Have you cleaned out the spray nozzle? This can become blocked.
29th Jan 2019 11:56am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
As far as I know, there are 3 separate pumps all attached to the fluid bottle, the pumps all being the same, front rear and headlamps. It should be fairly straight forward to swap the pumps and or pump some air through the rear hose to see if its the pump or a blocked hose. You could also try blowing from the tailgate end.
30th Jan 2019 9:31am |
