Home > Maintenance & Mods (L322) > Rear washer not working..
RRAustria
Austria 2004 Range Rover HSE Td6 Bonatti Grey
My rear washer doesn't work but this one has me stumped:
I can hear the pump working but no water - even after I disconnected the hose from the one-way valve at the wiper motor. What else could it be if not the pump or valve?
Thanks
Post #503174 29th Jan 2019 12:08pm
loads on the forum re this, have a search..
theres also 3 helpful write ups in the wiki...
Post #503176 29th Jan 2019 12:19pm
RRAustria
Thanks Stan. Unfortunately I didn't find what I'm looking for. The wiki and most threads talk about faulty wiper motors/seals, non-return valves, pumps - all these possible causes have been ruled out in my case (pump is running, line is disconnected before one-way valve and motor).
Is it possible that the pump is running but too weak to pump the fluid to the rear? Where are the most likely areas that the hose can get pinched/ripped?
Post #503178 29th Jan 2019 12:43pm
Have you cleaned out the spray nozzle? This can become blocked.
Also check the non return valve .
Post #503180 29th Jan 2019 12:56pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
As far as I know, there are 3 separate pumps all attached to the fluid bottle, the pumps all being the same, front rear and headlamps. It should be fairly straight forward to swap the pumps and or pump some air through the rear hose to see if its the pump or a blocked hose. You could also try blowing from the tailgate end.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #503299 30th Jan 2019 10:31am
