![]() | Home > Technical (L405) > SDV8 Gearbox issue (LR approved warranty declined claim) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2556 ![]() ![]() ![]() |
There is a known problem with the transfer case operation that is resolved with flushing the transfer case oil then performing a transfer case re-calibration, which is an inbuilt function initiated by diagnostics. However the TC problem isn't normally associated with your vehicle's symptoms. The price seems high for the minimal work and oil involved so perhaps ask an independent workshop for a price to have it done anyway to see if the problem is resolved. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 749 ![]() ![]() |
Have you spoken directly with the warranty provider?
Foz01 Member Since: 26 Nov 2017 Location: Aberdeen Posts: 31 ![]() ![]() |
Does the Warranty increase exclusions or change based on age/miles? |
xjrsupercharger Member Since: 09 Feb 2014 Location: Weybridge, Surrey Posts: 8 ![]() ![]() |
I'm looking at buying a RR 2014 SDV8 from a main dealer based on the 2yr used warranty. I'm slightly alarmed at how this wouldn't be covered by a dealership warranty! What's their excuse? 2015 L405 SDV8 Autobiography
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
Lazy bar tenders who give no customer care once they have your money.
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Personally, I'm surprised that an issue with driving away can be resolved by 'flushing the transfer box' - this is permanently engaged (either in high or low)!
The transfer case issue shows-up when turning, particularly at slower speeds but not in a straight line, as the clutch grabs when it should slip when the front and rear wheels travel different distances. |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 ![]() ![]() ![]() |
Thats interesting..
Just flushing the TC won't fix this particular problem as re-calibration is also required. |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 135 ![]() ![]() ![]() |
Hi Apologies for the thread resurrection - as I'm a relative newbie to RR ownership, is there any way of being able to check the fluid levels in the main gearbox - easily? Also - how often should the gearbox fluids be changed? Is it part of a main service every X thousand miles? Mines on 82k miles - and today (especially when it was cold this morning) I had same symptoms of it being sluggish to pull away in first (horrid stop start traffic) - no thumping or thudding noises, and she will pull away if I give it some gas. Cheers Current Vogue SE 4.4 SDV8 Previous highlights Many Mini's! Audi S8 Audi A6 Avant (the petrol guzzling Bi-turbo) Subaru H6 3.0 Estate Peugeot 406 Coupe V6 Audi 80 Quattro Sport |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
('Also - how often should the gearbox fluids be changed? Is it part of a main service every X thousand miles?')
Thanks
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
I’d start by changing the gearbox oil. The Landrover “recommended” 160,000mile/10 year change interval is way too long. ZF, the gearbox manufacturer recommend 100,000km(60,000mile)/8 year changes see this
Thanks for the link.
