Home > Maintenance & Mods (L322) > Still squealing after replacing tensioner |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
The 4.4 belts do like to squeal when the cars have sat around for some time (like in your case when car is for sale and unused for some time!)
23rd Jan 2019 12:27am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I had a similar situation on my Touareg and in desperation is applied a tiny (and I mean tiny) amount of graphite powder (it used as a dry lubricant for locks) to the belt on both sides the result was instant and last silence. I repeated the treatment after about 20,000 miles to restore silence again, worked for me. BMW i3 Electric Car
23rd Jan 2019 5:14am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I had a similar issue on my td6.
23rd Jan 2019 9:32am |
dibber83 Member Since: 22 Sep 2012 Location: Taunton Posts: 22 |
Update:
23rd Jan 2019 2:57pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
Could it be that one or more idlers might also need doing and / or the belt. Mine squeaks from cold. My mechanic mate says change the lot in one go instead of chasing it but that's a much bigger job than just the tensioner Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Jan 2019 3:11pm |
Hi Rob, I did wonder this but most of what I have read here seems to pinpoint only the tensioner. If the graphite lubricant I’ve ordered doesn’t shut it up then I’ll be getting back on to the dealer, as like you said, the work to rectify is going to start escalating.
23rd Jan 2019 3:37pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
What you should have done was wash of the spilt coolant with clean water, and allow to dry, before starting the engine again |
23rd Jan 2019 3:42pm |
I know!
23rd Jan 2019 3:46pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Replace belt .If belt has been running out of line it will be out of shape and will squeal until it breaks not worth the risk .If you want to test belt a little talc powder will shut it up instantly good luck |
23rd Jan 2019 4:40pm |
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 |
rik has a point about the risk of belt breakage after its been running out of line.
23rd Jan 2019 5:17pm |
The belt running out of alignment is nothing to do with the belt, its the tensioner that moves out of alignment when the internal spring fails due to age/wear and then the belt has less and less contact with the tensioner until finally it falls off the side...
23rd Jan 2019 9:07pm |
So the graphite lubricant seems to have stopped the squealing for now, I’ll monitor over the coming weeks.
24th Jan 2019 2:14pm |
Just found it I think - LR056285 2012 4.4TDV8 AB
24th Jan 2019 2:20pm |
when you have the engine cover off, take out the pollen filter box (2 nuts) and check for any oil cooler leaks.....common issue. Just had mine done...plenty of posts on here about it so don't want to hijack this thread Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jan 2019 2:22pm |
