As the weather was so good today, I finally got around to fitting the new top breather hose on the PCV unit that @duckworthparts kindly sent last week, but while I was digging around the back of the engine I found a couple of additional problems that may be causing the occasional lumpy running.
Firstly the vacuum pipe from the air intake had become disconnected:
Secondly when I had a look at the back of the PCV valve itself there appeared to be 2 hoses missing (not my picture):
Both 1 and 2 don't have any pipes on them, and when the engine's running there is quite a suction on hose 1, but not much on 2. I may have missed it, but I can't find any reference to the vacuum system in the workshop manual, so does anyone know which pipes should be attached here?
Thirdly, there is a loose LPG hose that comes off a regulator type device. It did have a jubilee clip on it, so I imagine it has been attached somewhere, but its running fine on LPG so it doesn't seem vital.
And lastly, I found this hose on the left hand side of the engine bay (as you look at it from the front) with a bolt stuck in the end! By feel, I think it comes from the lower crankcase area, any idea anyone?
Does any one know where I can locate a detailed diagram of the vacuum/PCV/breather system as my knowledge of this isn't as good as it should be! But any help would be gratefully received please, especially on the pipes missing from the PCV body. David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
