Home > Technical (L322) > LCM Code and introduction
BackinBlack
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Hi all, I have recently sold my Disco 2 and bought a 2005 L322 TD6 and need a little help with the LCM code please. Sorry for the amount of detail as it's a bit long.
I have replaced the faulty LCM with one from a 2002 V8. The replacement LCM worked fine but kept saying check dipped beam so I got it recoded by someone local (free of charge) and now the side lights won't work and it keeps saying check brake lights. I have bought a PA Soft BMW scanner and it looks like I can recode the LCM if I can work out which bit of data to change. Anyone know which memory addresses to change and what values to write please?
Guessing I need to turn side lights on, and turn brake light test off due to being LED.
New LCM is HW 01/SW 12, old LCM is HW 07/SW 2.0 But I can't read the old LCM to get the old code.
Current code
LCM Coding data ( HC11PH8_-_3_(LCM) 6.914.071 hw:01 sw:12 ci:11 di:10 bi:00 )
00 : 0F 7D FF A0 04 5A 21 2F 07 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01 : 00 5E 1B 8B 65 63 65 11 03 13 8B 20 03 14 88 40 12 DB 01 4D F6 05 50 7C 05 50 5D 26 08 F6 05
02 : 51 27 03 7A 05 51 13 E3 02 03 15 DC 01 12 E3 02 0E 12 E1 01 0A 14 DC 01 C6 01 F7 05 52 20 23
03 : 12 E3 02 1F 13 E1 01 1B F6 05 52 27 09 5F F7 05 52 C6 32 F7 05 51 F6 05 51 27 05 15 DC 01 20
04 : 03 14 DC 01 39 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
05 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
06 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
07 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
08 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
09 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E : 00 27 7F 00 9A D2 DA 5C 56 EC 03 EA 00 88 88 88 88 71 5E 51 47 3F 36 2F 2F 2F 2F 2F 2F 2F DA
0F : F0 7D FF A0 00 5A 21 2F 07 28 00 00 00 00 00 A9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
11 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
12 : FF FF FF FF FF FF FF FF 1F FF 81 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 23 45 00 00 00
13 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks for reading
Post #502040 18th Jan 2019 8:06pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I am sure when I was having LCM trouble that I read petrol and diesel versions were differnt although I can't remember where. I ended up buying a secondhand one from Ebay USA as there re far more petrol ones over there, only paid £45 inc postage.
I think you need a TD6 one from the correct year or at least as you are asking for the coding but as I say year and model specific 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #502082 19th Jan 2019 9:57am
BackinBlack
Thanks for reply Drakes. Mine has had the headlights changed for the 2006 model so not sure if the original one was recoded anyway or changed to a later version. If the HW07 denotes the year then it has already been changed.
Post #502099 19th Jan 2019 11:59am
BackinBlack
Don't suppose anyone can post a copy of their code please?
Cheers
Post #502120 19th Jan 2019 2:35pm
BackinBlack
All sorted.
Managed to find a used LCM for my 2005 TD6 Facelift.
Post #502572 23rd Jan 2019 8:01pm
