![]() | Home > Technical (L322) > Heeeeeeelp ! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
when you clear the faults do you hear the pump start to run ?
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
I do if I do the steering reset , yes
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
check its not stuck on transport mode or something daft like that-also that the height sensor actuator arms have not inverted themselves giving weird readings |
when I got it 2 years ago its was stuck in transport mode , ive checked all the arms are moving well etc pal so that rules them out but how do it get it out of / check wether it is stuck ?? |
it all depends if you are using the solus pro,bmw inpa etc as to where you find it on the menu tbh
Ok so was that on the bmw X5 on solus pal ? Cant remember seeing it in the LR program , i have INPA so can look on there if neccessary
Another update , using delphi on the bmw X5 programme , i have the options of activating all suspension bits and turning off transport mode so that is good news , however the compressor isnt kicking in , the fuse in the boot had blown , i replaced but still nothing , if i activate say , the front strut i can hear faint clicks n wurs so its looking like ive goosed the compressor while testing it yesterday , opinions guys ?? |
so was it stuck in transport mode? |
I cant say for sure with the compressor not working , couple of can codes to delete but they never returned , as i said above , activate any part and i can hear things working so that suggests that its not but i did start by removing transport mode |
should be simply sorted once you fix the compressor-they seem a bit fragile if you ask them to do too much graft... |
What can i do to be 100% sure the comp is goosed ?? |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I had this exact same problem. Dont panic, nothing is broken at all.
As i said earlier pal , the comp isnt responding to any activation i try so i need to check the comp to be sure before looking at other possible causes , i have bo faukt codes either
Try powering the compressor directly from a battery .
