Home > Technical (L322) > Fitting Side Steps - - Problem
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
Installled the passenger side today (after re-tapping M6 and M8 threads Sad ) Then had a pig of a job to fit, then on the last legs, went to fit mudguard and the front is about an inch lower Big Cry Been told to pack out the rear M8 bolt with washers to raise the front up?? Anyone else had to do this to get to fit right??
Post #501444 13th Jan 2019 8:41pm
I fitted an aftermarket set of side steps and had exactly the same problem. Used quite a few stainless steel washers on both sides to get them to line up with the sills. Thumbs Up
Post #501445 13th Jan 2019 8:59pm
MadL322
cheers for that reassurance. it's the front that's low so guess to pack out the back M8 and hanger
Post #501449 13th Jan 2019 9:15pm
