Home > Maintenance & Mods (L322) > 6 Pot Brembos -Pads and measuring discs (thickness) - tips? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Found it
12th Jan 2019 2:37pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
£20 if you have got a local Halfords store ?
12th Jan 2019 2:46pm |
Just to save somebody looking it up, the workshop manual says:
Thanks Mike, terrible of Halfords to show that. It's the complete incorrect way to check a disc.
12th Jan 2019 2:50pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Try searching for brake disc calipers.
12th Jan 2019 3:27pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, I use Vernier calipers and two coins to check thickness. 2012 TDV8 Black Edition
12th Jan 2019 3:35pm |
I use button magnets instead of coins where they stick, not neccessarily on car discs, helps without having to hold them. Only downside is that they don't give indications of thickness at the bottom of scores on a disc etc. That needs point tips on a suitable micrometer but if they are that bad, then you probably need to do something along the lines of further work. Cheers
12th Jan 2019 3:56pm |
You could check the rears instead Greg, assuming it’s not raining down there, like it is up here.
12th Jan 2019 3:58pm |
Thanks guys.
Thank you rjff An instructor-level mechanic taught me to use micrometer. But I didn't know you could get brake disc callipers, will have a look. Results: NS measures 33.2mm (was also taught to measure NS, prizes for guessing why) Needs pads but discs not too bad at 33% allowable wear. Regarding pad vs rotor wear - My discs and pads were both done around two years ago before I bought it. Based on the 33.2mm measurement today, I'd say I could get another set of pads use, then replace both next time. Making it a sort of 2 to 1 pad to disc wear ratio if that makes sense. Is this typical? What's the consensus guys, shall I leave the discs? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
12th Jan 2019 4:18pm |
Greg
12th Jan 2019 10:37pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
Had digital vernier calipers for less than £10 in Lidl of late, plenty good enough for checking discs. |
12th Jan 2019 11:54pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 330 |
I’d leave the discs until next pad change 4.2 SC - sold , now bought back
13th Jan 2019 10:32am |
is there good machine shop in your neighborhood, Greg ? 2012 TDV8 Black Edition
13th Jan 2019 11:56am |
Why's that Nino?
13th Jan 2019 12:19pm |
