![]() | Home > General > Buying advice 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
You are unlikely to find one with lower mileage.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Thanks for the reply Baltic Blue and for the link. There´s really an incredible amount of info here.
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Its more like 10000 euros over priced, full brake overhaul £1500 plus it would need a very thorough service indeed. |
Thanks Brian!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
My guess was that it would have been replaced under warranty.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Priced about the same as over here in the Emerald Isle 2015 4.4 AB
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
A set of new tyres will be on the shopping list after a year of showroom. 20 inch x 5 are well in the 1500€ rangenfitted if proper rubber is choosen.
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
Any vehicle stood up for long periods of time can create problems but if it's been in a warm showroom then it's probably not as bad. Things like the battery will be knackered if they haven't disconnected it or had a conditioner on it. The tyres may have developed flat spots too by being stood up so long depends on the showroom floor. Things like ceramic tiles are hard and you'll notice flat spots when you take the car for a drive.
Foz01 Member Since: 26 Nov 2017 Location: Aberdeen Posts: 31 ![]() ![]() |
How much cheaper is it to a comparable car? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Way overpriced. No more than 30k with an extended warranty as the turbos need clean oil or they wear faster. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Thanks again for all input!
I offered £13,000 under what a local dealer wanted for a TDV8 yesterday, they declined but i suspect they now realise the true value of the car they are trying to sell.
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 140 ![]() ![]() |
"I offered £13,000 under what a local dealer wanted for a TDV8 yesterday, they declined but i suspect they now realise the true value of the car they are trying to sell. "
£65k, it was a 2015 4.4 AB, non franchise dealer, low miles but 10 miles up the road of the franchise dealer has a similar car with the 2yr LR warranty for 55k. |
