Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 799 |
Comment from Marsie that the 8 speed gearbox cannot be flushed.
6th Jan 2019 10:46pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 334 |
Rambles
6th Jan 2019 10:55pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
trickier to flush the 8 speed as there is a thermostat in the oil cooler lines so that needs to be open to flush using the cooler lines as they do on the 6 sp and 5 sp, its not electronical so would need actua fluidl heat to open but then as soon as you put cool oil in it will shut.
7th Jan 2019 8:49pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
8 speed can be Megaflush. Quite a few places do it now. Mine being done by Bodsy on my drive in 2 weeks Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Jan 2019 9:17pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 327 |
If the IID tool shows that a SW upgrade is available when scanned you should be able to get it from GAP - or at least ask them 4.2 SC - sold , now bought back
7th Jan 2019 9:19pm |
Thanks M@tt. I’ll have a look tomorrow. I believe the upgrade is located in the PCM section |
7th Jan 2019 9:53pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Millerj90, did you find anything more out about this? I'd be interested to know if mine has it as it does seem to suffer from hesitation. 2010 4.4 TDV8 Vogue SE |
21st Jan 2019 2:40pm |
Kooky
21st Jan 2019 5:20pm |
I’ve been i. Touch wth the great guysfrom GAP. Patrick has informed me that the PCM reflash via the IID tool is unlikely to clear the problems mentioned in LTB00454v2 - Engine Hesitation |
26th Jan 2019 6:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
you'll have get a dealer to sort it then.. |
26th Jan 2019 7:37pm |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
Can you guys, who have done the PCM update by LTB00454v2, share your PCM (or ECM) data? I want to know if mine has been done, so need comparsion data. I've also felt a juddering few times, while cruising at highway speeds over 110 km/h. Really worrysome feeling.
10th Nov 2022 9:07am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3195 |
Had my box updated last month;
10th Nov 2022 9:56am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Mine was updated supposedly to the latest level for a non-DPF engine June 2020.
10th Nov 2022 10:04am |
