Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish
Page 4 of 4 <1234
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Trantorman wrote:
does anyone know if this can be done with the IID Tool, or if its main dealer only, mine does it and at high speed when you lift off its really disconcerting and annoying.
Sorry to reassurect an old thread. But would any of the updates to the IID tool now allow this to be done?
LTB00454v2 - Engine Hesitation/Powertrain Control Module Update
Post #500808 6th Jan 2019 10:30pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Comment from Marsie that the 8 speed gearbox cannot be flushed.
Plenty of threads on this forum about 8 speeds being flushed, or am I mistaken?
Post #500813 6th Jan 2019 10:46pm
millerj90
Rambles
I was more referring to the software update mentioned in the TSB, and if it could now be done by the IID tool, or is it still a dealer visit.
Regards
Post #500816 6th Jan 2019 10:55pm
trickier to flush the 8 speed as there is a thermostat in the oil cooler lines so that needs to be open to flush using the cooler lines as they do on the 6 sp and 5 sp, its not electronical so would need actua fluidl heat to open but then as soon as you put cool oil in it will shut.
Lots of folks changing the oil, incl me, but not sure about flushing. There is nothing that can't be fixed with a hammer😜😜
Post #500889 7th Jan 2019 8:49pm
DrRob
8 speed can be Megaflush. Quite a few places do it now. Mine being done by Bodsy on my drive in 2 weeks Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #500891 7th Jan 2019 9:17pm
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
If the IID tool shows that a SW upgrade is available when scanned you should be able to get it from GAP - or at least ask them 4.4 AdBlu Tractor Stolen
4.2 SC - sold
Post #500892 7th Jan 2019 9:19pm
millerj90
Thanks M@tt. I’ll have a look tomorrow. I believe the upgrade is located in the PCM section
Post #500894 7th Jan 2019 9:53pm
kooky_guy
Millerj90, did you find anything more out about this? I'd be interested to know if mine has it as it does seem to suffer from hesitation. 2010 4.4 TDV8 Vogue SE
Post #502292 21st Jan 2019 2:40pm
millerj90
Kooky
Sorry not had the time, or inclination due to cold weather to get out with my IID tool to see if any of the available GAP updates satisfy the requirement.
I’m also a bit loathed to apply and update in the drive. If it goes wrong you’re FUBARBed. If the garage screw it up, they’ve got to sort it.
I’ll update this thread as soon as I get around to it.
John
Post #502304 21st Jan 2019 5:20pm
millerj90
I’ve been i. Touch wth the great guysfrom GAP. Patrick has informed me that the PCM reflash via the IID tool is unlikely to clear the problems mentioned in LTB00454v2 - Engine Hesitation
Post #502878 26th Jan 2019 6:14pm
you'll have get a dealer to sort it then.. Neutral
Post #502885 26th Jan 2019 7:37pm
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
Can you guys, who have done the PCM update by LTB00454v2, share your PCM (or ECM) data? I want to know if mine has been done, so need comparsion data. I've also felt a juddering few times, while cruising at highway speeds over 110 km/h. Really worrysome feeling.
My PCM data is here:
PCM-Engine TDV8 4.4L (No update found)
Assembly (F113)
BH42-12A650-NAD
Calibration (F124)
BH42-12K532-NTL
Hardware (F111)
BH42-12B684-NA
Serial
1373020506111015
Strategy (F188)
BH42-14C204-NTD
Hope someone would find a minute to pull and share data. Smile
Cheers
Keijo
Post #647806 10th Nov 2022 9:07am
JayGee
Had my box updated last month;
Assembly Part number: BH42-7Z369-HK
Hardware Part Number BH42-14C247-HB
Software Bootloader part number: BH42-7J244-HB.vbf
Didn't have any hesitation issues before this update. 2012 TDV8 Vogue (L322)
Post #647811 10th Nov 2022 9:56am
GraemeS
Mine was updated supposedly to the latest level for a non-DPF engine June 2020.
Assembly (F113) BH42-12A650-NAD -> BH42-12A650-NCK
Calibration (F124) BH42-12K532-NCK = Up-to-date
Hardware (F111) BH42-12B684-NA = Up-to-date
Strategy (F188) BH42-14C204-NTD = Up-to-date
This suggests that the assembly component isn't at the latest level but the update fixed the light surge at 110 kph when using cruise control.
Prior to the update:
Assembly (F113) BH42-12A650-NAC -> BH42-12A650-NCK
Calibration (F124) BH42-12K532-NCH -> BH42-12K532-NCK
Strategy (F188) BH42-14C204-NTC -> BH42-14C204-NTD
I must check the current status having just had EGR disabled and a light tune to see if its any different, which I doubt.
Post #647812 10th Nov 2022 10:04am
Page 4 of 4 <1234
