Home > Off Topic > New windows - Accoya vs Sapele ? |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 |
For what it worth the joiner I use only uses accoya - has something like a 50 year rot guarantee as well. It can be a bit oily so need to make sure you use the right paint. I have just had a load of sash windows done as well and I would recommend getting them spray finished by the person making them if you can rather than painting when installed. I have fitted some sash restrictions and drilling the holes you can tell it is pretty hard/solid wood.
5th Jan 2019 8:57pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
I would certainly recommend using accoya as it has a much longer life. I specify it for any outside joinery and have been pleased with it. |
5th Jan 2019 9:19pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Many thanks for the replies.
Any noise experts? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 6th Jan 2019 9:04am. Edited 1 time in total |
6th Jan 2019 8:09am |
I am not a noise expert (!) but I can’t see that the wood will have any impact on the noise transmission as you will get more noise leakage through the brush seals that you have to have with a sash window to allow them to slide up and down so any benefit between the woods would be lost there anyway. Just my thoughts! |
6th Jan 2019 8:37am |
That's a fair point
6th Jan 2019 8:49am |
Maybe that's why I can't find any definitive tests or statements....
6th Jan 2019 8:52am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
+1 It's surprising how a relatively small gap in a structure can almost totally negate the sound isolating effect of that structure. |
6th Jan 2019 10:36am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Timber sash windows will never be super great for noise. But that said newly made ones can be produced with fairly tight tolerances and are no where near as leaky as an old set. Never going to be as noise proof as a casement window but can be reasonably decent. Timber wise it won’t make a hill of beans in terms of which wood you choose. The biggest factor will be the glass and how tight and well sealed the sash is into the frame. Triple glazing will make a difference but not as much as you might think and the cost/benefit might not be there.
6th Jan 2019 12:08pm |
Thanks Mark. Taking the noise factor away then, which would you go for, Accoya or Sapele ?
6th Jan 2019 12:14pm |
Wood is wood basically, it’s all down to protection and painting. Hardwood windows will rot too, not as much as softwood but if not correctly treated they will still rot. The windows I fit in the new houses are treated softwood, and spray painted in the factory. They come with an 8 year warranty on the paint finish alone.
6th Jan 2019 12:24pm |
Thx
6th Jan 2019 1:10pm |
Chaps, should Accoya be more expensive than hardwood?
11th Jan 2019 12:05pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1230 |
I was going to suggest oak but then looked this up..
11th Jan 2019 12:50pm |
