Home > Off Topic > New windows - Accoya vs Sapele ?
GGDR
Hi guys,
Interested in any views here, about to pull the trigger on some new sash windows.
It's coming down to one last choice:
Accoya is a treated softwood that's said to be rot-proof. I've been told today it'll move less than hardwood
vs
Sapele dense stable hardwood
- The windows are west facing and take a good amount of afternoon sun.
- I want the best noise performance
Many thanks!
(typo corrected above) Cheers, Greg
Post #500674 5th Jan 2019 6:11pm
Tooltime79
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
For what it worth the joiner I use only uses accoya - has something like a 50 year rot guarantee as well. It can be a bit oily so need to make sure you use the right paint. I have just had a load of sash windows done as well and I would recommend getting them spray finished by the person making them if you can rather than painting when installed. I have fitted some sash restrictions and drilling the holes you can tell it is pretty hard/solid wood.
Cheers
Tim
Post #500696 5th Jan 2019 8:57pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I would certainly recommend using accoya as it has a much longer life. I specify it for any outside joinery and have been pleased with it.
Post #500700 5th Jan 2019 9:19pm
GGDR
Many thanks for the replies.
As far as noise goes, there is nothing I can find online about which is better.
Hardwood is definitely denser, then I read something complicated about mass vs density. Shocked did not comprehend that one Big Cry
Reading about noise performance for windows, there is plenty about the glazing but nothing really about the frame material.
The only statement I found on a joiners website was:
Quote:
we have timber doors to suit everyone, whether you’re looking for a high density hardwood door to minimise the noise of traffic, or an incredibly durable Accoya wood door with a fantastic lifetime.
Any noise experts?
. Cheers, Greg
Post #500723 6th Jan 2019 8:09am
Tooltime79
I am not a noise expert (!) but I can’t see that the wood will have any impact on the noise transmission as you will get more noise leakage through the brush seals that you have to have with a sash window to allow them to slide up and down so any benefit between the woods would be lost there anyway. Just my thoughts!
Post #500725 6th Jan 2019 8:37am
GGDR
That's a fair point Thumbs Up
. Cheers, Greg
Post #500727 6th Jan 2019 8:49am
GGDR
Maybe that's why I can't find any definitive tests or statements....
The above quote relates to doors, a big lump of wood pressed hard against a rubber seal. In this case you could compare materials with more meaning. As opposed to a sliding wooden frame(s) with big bits of glass in them. And brush seals.
. Cheers, Greg
Post #500728 6th Jan 2019 8:52am
+1 It's surprising how a relatively small gap in a structure can almost totally negate the sound isolating effect of that structure. Thumbs Up
Post #500740 6th Jan 2019 10:36am
Timber sash windows will never be super great for noise. But that said newly made ones can be produced with fairly tight tolerances and are no where near as leaky as an old set. Never going to be as noise proof as a casement window but can be reasonably decent. Timber wise it won’t make a hill of beans in terms of which wood you choose. The biggest factor will be the glass and how tight and well sealed the sash is into the frame. Triple glazing will make a difference but not as much as you might think and the cost/benefit might not be there.
Ive has several houses worth of casement windows off these guys and they may have some data sheets which you could use for comparison
https://commercial.west-port.co.uk/performance/ There is nothing that can't be fixed with a hammer😜😜
Post #500745 6th Jan 2019 12:08pm
GGDR
Thanks Mark. Taking the noise factor away then, which would you go for, Accoya or Sapele ?
. Cheers, Greg
Post #500748 6th Jan 2019 12:14pm
Wood is wood basically, it’s all down to protection and painting. Hardwood windows will rot too, not as much as softwood but if not correctly treated they will still rot. The windows I fit in the new houses are treated softwood, and spray painted in the factory. They come with an 8 year warranty on the paint finish alone.
So if it was me I would go with the accoya. Treat them well and they will last well. I have standard softwood windows in my house 15 years on and there is no rot, professionally painted every 3-4 years to keep them up to date. There is nothing that can't be fixed with a hammer😜😜
Post #500749 6th Jan 2019 12:24pm
GGDR
Thx Thumbs Up
. Cheers, Greg
Post #500755 6th Jan 2019 1:10pm
GGDR
Chaps, should Accoya be more expensive than hardwood?
. Cheers, Greg
Post #501206 11th Jan 2019 12:05pm
Bill
I was going to suggest oak but then looked this up..
http://www.internationaltimber.com/range/m...s/accoya-r
Looks like good stuff...
I don’t like repainting things so maybe staining is best and would agree a double glazed unit is better than single for noise. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #501211 11th Jan 2019 12:50pm
