![]() | Home > Technical (L405) > Headlights |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
So have managed to adjust and hopefully sort this out. Once you remove the plastic cover trim held by three plastic “screws” and expose top of unit the white adjuster on top is the vertical adjust. Requires a 6mm Allen key. I marked the position of the white adjuster as a reference point with a scribe and then using the garage door with headlights on made same gentle adjustment to lower the beam impact centre point 2 inches below where they were for both lights. I then went through the rough exercise using the yard and wall outside to check the beam pattern at 25ft. A bit rough and ready and I will get them aligned properly at the dealer on next visit but seems to have done the trick. Thanks guys for the help |
Glad you got it sorted sir |
