Home > Technical (L405) > Headlights
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Headlights
Guys,
One hopes Santa has been kind to you all Very Happy
2014 L405 AB sc
I am finding drivers are flashing or going to high beam at night when I have my dipped headlights on. I have checked the manual (no adjustment other than L or R for adaptive in menu and set on L) and I carry no weight in the car. I appreciate we are higher on the road compared to cars.
This is my first winter, night driving, with my ( new to me) L405 and I did not have same issue on my previous L322. The lights are far superior to my previous RR and throw a wider, longer, brighter pattern.
On level ground the car seems to look from the side visually slightly higher at the front than rear but on checking the ride heights in normal mode they are stock per LR.
Has anyone else experienced a similar issue or TADTS?
HNY!
Ipslore
Post #500150 31st Dec 2018 2:30am
Not had a problem with mine
Do you have MOTs over there ? The lights will be checked as part of that and would tell you if they are misaligned, so any place that does an MOT can check them.
Post #500154 31st Dec 2018 9:24am
i have read that some members say the L405 headlights are not very good so its possible that the previous owner has manually adjusted the lights 'upwards' so they illuminate the road a bit more...
do as Alistair suggests and get them checked.
Post #500159 31st Dec 2018 9:43am
Ipslore
@ Alastair - no MOT here but cars have to meet equivalent standards as the UK bar the emissions test. I’ll get the dealer to check it as she is going in for some other bits in a few weeks time.
@ Stan - yes, sounds the way forward.
Thanks both. Thumbs Up
HNY!
Andy
Post #500195 31st Dec 2018 4:23pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Ive never driven a ‘322, so I can’t compare, but the headlights on my own L405 are at least as good as the very best headlights that I’ve had before Thumbs Up
What I do find is that if I’m approaching the crown of a hill and someone’s coming the other way, they often get the full affect of the dipped dean and I often get flashed as they must be assuming that I’m on main beam.
Post #500214 31st Dec 2018 7:26pm
Vogue
As much as it pains me to say it, but yes the headlights in the last of the 322’s were better - but then the surface area of the lights was far greater and far less streamlined 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #500225 31st Dec 2018 10:20pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Agreed my 2011 L322 headlights were epic, the L405 ones are merely good 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #500227 31st Dec 2018 11:21pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
My L405 lights seem to be set too low...any ideas how I can raise them? I really struggle to see very far ahead..and yes my eyes have been checked!!
Post #500440 3rd Jan 2019 5:09pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Think we have had that question before and I agree, but short of waiting for Craig to finalise his upgrade there does not seem to be an answer. letters not necessarily in the right order
Post #500445 3rd Jan 2019 6:26pm
@jase, looks like theres only a horizontal adjustment...
Post #500447 3rd Jan 2019 6:49pm
Jase71
Thanks @stan 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #500516 4th Jan 2019 5:55pm
These may help... Took some pics of the rear of one i have on the shelf today and there are clearly two adjusters... So, one for Left & Right and the other for Up & Down...
I would guess the lower one does the Up & Down movement... Neutral
Hope they help Thumbs Up
Post #500521 4th Jan 2019 6:24pm
ah my bad..i looked on the L494 workshop manual and it only showed the horizontal adjustment and i thought the self levelling would take care of the vertical adjustment.....
Post #500523 4th Jan 2019 6:34pm
Dooooooh. Ner Ner Rolling with laughter Bow down
Post #500525 4th Jan 2019 6:46pm
Ipslore
Thumbs Up Top man CTC! Thank you. I’ll have a look and play with them in the garage and see.
Post #500676 5th Jan 2019 7:33pm
